| | | Forums66 Topics128,167 Posts1,057,015 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 2,832 'Bolter | | 'Bolter Joined: Apr 2005 Posts: 2,832 | These are flathead Ford type mounts and both CE and Speedway offer different length mount brackets that you can cut to size to fit your frame. They are a very clean set up that doesn't block pan access but if one is using a fire breathing torque monster then a tube that joins the frame rails together and has the mounts on it is a better choice. Any mount bracket that attaches to just one frame rail always has a twist on that rail from both weight and torque. Factory mounts are usually on or very near a crossmember. Fine for 90% of applications.
Evan
