You can be pretty much be ensured that they are supplied from off shore and are relatively the same. Mine came via Taiwan, but actually fit very well. All the mounting holes lined up and had enough adjustment in it for corrections. It did not have the running board holes, so I drilled those and the inner support strap was a wider width, but is sufficient. Shop for the best price including shipping is my opinion.
Drew
