| | | Forums66 Topics128,038 Posts1,055,583 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2008 Posts: 899 'Bolter | | 'Bolter Joined: Apr 2008 Posts: 899 | I use an inductive timing light to check my ignition. Each plug wire should have steady flashing with no skips as the engine runs. Also, have you checked that the vacuum advance is working? Distributor should physically turn when you rev the engine. I had a similar problem as you last year and ended up replacing the distributor. Runs great since then, fires right up even after sitting a couple days.
Ed
