9 members (Mike B, Gdads51, Sjm, TooMany2count, 52Carl, greenie-reddy, 78buckshot, Wayne67vert, Wally / Montana),
98
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,262 Posts1,058,331 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2008 Posts: 293 Shop Shark | | Shop Shark Joined: Nov 2008 Posts: 293 | In my 66 Suburban, I have the 292 motor with the smog pump and system. I need to rebuild my carburetor, but I am not sure if I have the correct carb or not. According to the 66 Shop Manual, there is a different carb for the non smog motor (7024009) and for the smog motor (7036009). My carb does not have a metal tag on it with the part number on it. Is there a way to identify my carb and does anyone know what the difference is between the 2 carbs, as far as a rebuild kit is concerned? Thank you for your help. | | |
