| | | Forums66 Topics128,268 Posts1,058,375 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 10,335 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,335 | The only way that I could effectively use the Factory Manual instructions was to write them down line-by-line in MY language. Once i did this, it all started to click. As far as which bolts to loosen. ALL OF THEM. Including the lower radiator support-to-cross member bolts. The hood is adjusted with the springs removed. It is important to put pressure on the back end of the hood while adjusting the fore/aft alignment (with a 4 inch block under the nose of the hood). I place a short section of railroad rail on a thick towel for this pressure. Failure to apply this prescribed pressure is usually what causes the back of the hood to stick up once the springs are reinstalled. Carl
