Originally Posted by zmaxmotorsports
Im saying that once we installed the narrowed crossmember everything else for the independent front suspension bolts to it for the most part.
Then you can mount the newer steering can be mounted up,giving you all kinds of room for any v8 you want to drop in there.
Back of radiator mount/cross member gets clearance just a little for clearance.
The suspension from late 60s-80s chevy 2wd trucks is basically same design from 1/2t-1t trucks.
So even on the 1/2t version youll need to narrow the newer crossmembe to fit. wink
I like apples and I like oranges, and I like people who take the time to try to help, but I am asking how to install a 350 and power steering in a 1/2 ton AD with a stock 'everything else'. Far be it from me to call out "off topic", as I may well be the biggest violator of that particular rule on this site. Just trying to entice focus.
Thank you,
Carl
