| | | Forums66 Topics128,089 Posts1,056,418 Members48,443 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,826 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,826 | I think you're confusing your terms, or at least confusing ME. The tie rod connects the steering arms with each other, right and left. Are you considering making shorter steering arms, the parts that bolt onto the spindles? That could possibly result in too straight an angle between the tie rod and the steering arm at full turn right or left, resulting in a locked-up situation. Be sure to set the steering stops to prevent getting the angle too close to straight when you reach full travel of the spindles. It's possible you'll lose some of the angularity possible at full travel if you shorten the steering arms that much. What's the necessity for using a shorter steering arm? Jerry
