| | | Forums66 Topics128,066 Posts1,055,876 Members48,428 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2013 Posts: 9 'Bolter | | 'Bolter Joined: Feb 2013 Posts: 9 | I have a carburated 350 (target engine) that used to have an auto tranny behind it. I have a 3 speed OD that I would like to use with this engine in my 66 half ton. The 3sp OD was on a 265, the 265 bellhousing bolts up okay to the 350. The trouble is the starters, the old one is 3 bolt and the one that was on the 350 is 2 bolts. What direction do I need to go to fix this problem ? Any ideas or suggestions would be appreciated. | | |
