| | | Forums66 Topics128,156 Posts1,057,020 Members48,460 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Mar 2010 Posts: 10,303 Renaissance Man | | Renaissance Man Joined: Mar 2010 Posts: 10,303 | Is there a pinch weld at the bottom edge of the belt line similar to the ADs? If so I would recommend a panel which eliminates this rust prone area. I have repaired this area on an AD with a TIG welder, but it was a HUGE challenge. There is no longer a pinch weld there. I removed 1/2 of the height of the belt bulge above the pinch weld from lock pillar to lock pillar, and welded many, many small patch pieces to account for all of the compound curves in this part of the cab. Carl
