1 members (UtahYork),
80
2
Mod | | | Forums66 Topics128,049 Posts1,055,637 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2006 Posts: 2,544 Shop Shark | | Shop Shark Joined: Nov 2006 Posts: 2,544 | You won't have any problem getting the motor out. I would be careful moving it with the engine out. You will also want to make sure that the torque converter has a bracket off one of the bellhousing bolts to keep it from coming out of the transmission. A piece of 1/4 flat stock with a 3/8" hole in one end will work to bolt to transmission, then have a slight bend in the strap to push against the converter to hold it in. | | |
