The late rear end was probably put there to give a more desirable highway worthy gear ratio. If you put in the original you will be limited to about 55 MPH. Then you will be looking for some kind of o-drive to put in. The late rear end probably takes the same wheels.
1972 Chevy c10 Cheyenne Super
In the Gallery Forum
