0 members (),
102
3
Mod | | | Forums66 Topics128,186 Posts1,057,319 Members48,469 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | Here are some perches on a Dana 80 that I modified to fit narrower springs on the slightly wider perches. In this case the spacing was already correct. https://picasaweb.google.com/lh/photo/ydeakI-wVgnJH8jITsPJ99MTjNZETYmyPJy0liipFm0?feat=directlinkBetter yet is if you have the original rear axle to the truck it very likely has 4" tubes same as the Dana 80. Remove those perches to use on the Dana 80. I have a pair saved from my 2 ton axle for the next time I get in this situation. Grigg | | |
