| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,844 | Yes, it can. If the regulator supplies full voltage to the field coils the alternator will go into full current output and severely overcharge the battery. A shorted power transistor in the regulator will full-field it. At speeds above idle, the voltage can go to 20+ volts or more. Jerry
