| | | Forums66 Topics128,051 Posts1,055,734 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2001 Posts: 3,458 Extreme Gabster | | Extreme Gabster Joined: Oct 2001 Posts: 3,458 | I used about a gallon on a CJ-5 jeep body I did. I suspect that would be about the same amount of metal as your cab and doors (assuming you are doing inside and out). It depends on what kind of gun you are using, you waste about 25% more with a conventional gun than you do an HVLP.
