| | | Forums66 Topics128,258 Posts1,058,332 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2005 Posts: 345 Shop Shark | | Shop Shark Joined: Apr 2005 Posts: 345 | I elected to do a frame swap rather than swapping out the front end. If you do the front end clip, you will probably want to change our your rear axle to a 5 lug so that your wheels will match. You will probably also want to lower and make less stiff your rear suspension to match what you are putting on the front.
Beyond that you will probably need to realign/reconfigure your steering shaft to fit the new steering box, and you may need to rework your brakes. There are some pretty thorough threads on this site and others regarding front end swaps. | | |
