7 members (EchoBravoSierra, MNSmith, TUTS 59, Goach2, LAROKE, Gray_Ghost, Lightholder's Dad),
87
2
Mod | | | Forums66 Topics128,173 Posts1,057,041 Members48,458 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2013 Posts: 293 'Bolter | | 'Bolter Joined: Aug 2013 Posts: 293 | Hi Kent; I saw on here someone mentioned removing the existing tubes and using new 16" tubes with your original 17" split rims then using modern 17" radials. I'm also finding it is difficult to locate a narrower wheel/tire with rim offset to clear the rear inner fender wall. I have tried using 16" wheels and tires off a 1992 Dodge 2500 that clear the front tie rod ends and rear inner fender wells but I don't really want to go the 16" route as my top speed will drop even more than it all ready is. All though I could just change to 4:11 gears but I would like to keep as original as possible. | | |
