It is a simple job. Like Box says use a good tubeing wrench. There are 2 bolts holding them on. One bolt on the front is hard to get at because the hose fitting goes by close to it. You don't need to remove the shoes. Remove the return springs & spread them out a little.
1972 Chevy c10 Cheyenne Super
In the Gallery Forum
