| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,951 | 235 rods are not scarce or expensive. Use a sawzall or a cutting torch on the frozen-up rods to get the crank out of the block and buy a couple of replacement rods when you reassemble the engine. Chances are they're junk anyway. Jerry
