| Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,958 | The road draft tube only ventilates effectively at speeds above 30 MPH. That's one good reason to convert to a PCV system instead of using road speed to cause a ventilation flow through the crankcase. Jerry
