The stock steering is, in theory, just about the best type of steering box you can get. It may need to be rebuilt and even if it doesn't, a good idea would be to check it and be sure the bearings and bushing are in good condition. These boxes are easy to rebuild and if you can adjust them out before you reinstall it in the truck, you should have just about the best you can have.
