| | | Forums66 Topics128,131 Posts1,056,723 Members48,454 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,840 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,840 | SAE (Society of Automotive Engineers) has published standard torque values for just about every common bolt used on vehicles. I believe the 1/2-20 torque spec is somewhere in the 100 ft/lb range. A good rule of thumb that I've used for a lot of years on bolts without a published torque specification is "snug plus one flat". Take up the slack between parts until you can feel the resistance to turning change, and tighten the bolt or nut another 1/6 turn (one flat on a hex-head bolt). This puts a slight amount of "stretch" on the fastener and prevents it from loosening. It works on just about any size fastener. Jerry
