Well, after looking things over with carb off, I could see that I wasn't getting full throttle from the linkage, Had to get it further away from the throttle body so it wouldn't hit the throttle shaft arm. Even cut away a liitle from the arm. Tight fit for the linkage being threaded thru the fenton headers. I'm not convinced the weber holley is the best single carb set up' but it is affordable.
[url=http://www.stovebolt.com/gallery/shannon_joe_1953.html]1953 Chevy 3100[/ur When life looks like easy street there is danger at your door
