| | | Forums66 Topics128,101 Posts1,056,178 Members48,436 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2006 Posts: 2,393 Shop Shark | | Shop Shark Joined: Sep 2006 Posts: 2,393 | There is one or two good ideas in the Tech Tips section. You Tube has a few. All deal with inserting a spacer or support to keep the spring expanded as you close the hood, the spring stays enlongated and slips off the hooks. You an use washers if you want. Just takes a few large thick ones.
Drew
