Hi welcome to the site, I have been looking for the better part of 1 year for a replacement tire to fit my 3 piece rims with not much luck. I'm thinking of trying to fit a 205 or 215 x 17 tire to my split rim and still use a tube. Not sure if it will work but lots of cheap tires around for less than 50.00. If you find a tire to fit let me know. One of the 16" rims that do fit and clear the front tie rod is off a 92 Dodge ram 2500.Some of the later model Ford 3/4 ton rims are supposed to fit too.
