Sure Phat, but you would only use it in a very small area.
As a rule, you use as large a block as you can fit on the area being worked.
So the paint stick would be used in a very small area. It also works great for sanding out a run in the top coat for buffing.
1948 Chevy Pickup
Chopped and sectioned
owned since 1974 when I was 15.
