1 members (Ponchogl),
108
2
Mod | | | Forums66 Topics128,281 Posts1,058,466 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Nov 2009 Posts: 639 'Bolter | | 'Bolter Joined: Nov 2009 Posts: 639 | Lancer70, I finished my T5 install yesterday. With the engine off it shifted fine through the gears, with the engine running I couldn't get it into gear. I adjusted the clutch and it works great. I still believe you need to lengthen the input shaft splines, but also recheck your clutch adjustment. | | | |
Entire Thread
58 truck with T-5 trans problem, help
| lancer70 | 09/15/2014 7:14 PM |
Re: 58 truck with T-5 trans problem, help
| twotone | 09/15/2014 7:21 PM |
| lancer70 | 09/15/2014 7:29 PM |
| twotone | 09/15/2014 7:42 PM |
| lancer70 | 09/15/2014 8:15 PM |
| Lugnutz | 09/15/2014 9:37 PM |
| lancer70 | 09/15/2014 10:12 PM |
| Lugnutz | 09/16/2014 2:28 AM |
| Pre '68 Dave | 09/16/2014 2:44 AM |
| Lugnutz | 09/16/2014 3:19 AM |
| Wrenchbender Ret. | 09/17/2014 8:55 PM |
| fiftee3 | 09/17/2014 11:24 PM |
| twotone | 09/18/2014 12:09 AM |
| Bread | 09/20/2014 5:27 PM |
| Lugnutz | 09/22/2014 12:35 PM |
| ryanz | 09/20/2014 9:16 PM | |
