Originally Posted by 3B
Hy mikec4193, I believe your link shows a picture of a rear brake drum, I thought you wanted to convert from dual wheel style front hubs to single wheel style front hubs, or did I misinterpret something again?
Hi 3B
Yuppers you were right. I was just trying to get the same width track from front to back. It appears as tho this spacer is to keep the front track the same width as the dual rear wheels are. The rock auto photo claims this drum fits front or rear. I am new at this stock truck stuff. I am also thinking now about doing a front disc brake conversion. I have read that a 1979 K20 disc brake will work on this truck. I am still researching my options. I want to keep as much stock as I can but make it safer with better brakes and better rear gearing too.
MikeC
1951 Chevy 3800 1-Ton
Howard Knapp
