8 members (kurbside bolter, tclederman, FAST55, Hotrod Lincoln, KEVINSKI, 1955 1 Series, Charles in CA, Otto Skorzeny),
153
2
Mod | | | Forums66 Topics128,267 Posts1,058,373 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
#10562 04/22/2002 3:48 AM | Joined: May 2001 Posts: 41 Member | | Member Joined: May 2001 Posts: 41 | If you changed the oil filter and didn't fill it before you installed the new one it will take quiet awhile to get oil to pump anywhere else first. It will try to fill the filter up.
37 Chevy 1/2 Ton 86 Chevy Blazer 98 Drudge 24 valve Cummins One worn out Timberjack
