| | | Forums66 Topics128,281 Posts1,058,476 Members48,490 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2001 Posts: 40 Member | | Member Joined: Feb 2001 Posts: 40 | I plan on using a truck bed coating made by duplicolor you apply with a special roller . I already did the underside and inside of the cab and the underside of the running boards . I may even put two coats on the rear fenders because the are fiberglass and hopefully it will prevent rock starbursts . | | |
