I unhooked the speedo cable from the back of the speedo head and found that the cable does turn while driving, so that tells me the problem is in the speedo head. First question, I took the screws out for the instrument cluster but am unable to pull it out from the front of the dash, is there a trick to this? (no wires are holding it in)
Can you repair a speedo head yourself, if not where would I get it repaired?
