| | | Forums66 Topics128,197 Posts1,057,259 Members48,466 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2006 Posts: 9,671 'Bolter | | 'Bolter Joined: Oct 2006 Posts: 9,671 | You don't want to use copper Dave, it will eventually fatigue from vibration. If it's mounted ridged on the engine you could use Steel lines, but originally it would have flexible hydraulic hoses. You've been around the 'bolt long enough that I'm sure you've seen the many discussions and illustrations on how they were plumbed in to the Stovebolt sixes. The later is definitely the way I would go.
DG
Denny G Sandwich, IL
