0 members (),
77
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,030 Posts1,055,428 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Aug 2010 Posts: 775 'Bolter | | 'Bolter Joined: Aug 2010 Posts: 775 | You might be able to remove it without removing the floor pan and toe board but as recall even with those removed it is tight. Also did you check for power at the terminal block on the fender? That would tell you if the switch is bad unless of course a wire went bad between the switch and the terminal block.there should be no power to the switch unless the headlights are on but disconnect the battery after you check for power at the terminal block. | | |
