| | | Forums66 Topics128,024 Posts1,055,395 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jan 2011 Posts: 306 'Bolter | | 'Bolter Joined: Jan 2011 Posts: 306 | I replaced the 4sp granny low with a new process a833 (rpo my6) on my 53 3/4 ton. I replaced the 5:14 rear with a 4:11 and had a one piece open drive shaft made for it. the trans has a pad under the tail cone that would sit on a cross member support if there was one on my truck.
my question is should I put one in or just let it hang like the old one did?
thanks rolf
1963 c10 | | |
