| | | Forums66 Topics128,049 Posts1,055,689 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2000 Posts: 986 'Bolter | | 'Bolter Joined: Feb 2000 Posts: 986 | steve_h I think you missed the part of the starter being rebuilt. I think it may still be the starter but I think it may be too tight. It may be that the rebuilder built it as if it were going to use 12 volts. It may have too much friction. Creating too much load.
If it were me I would pull all the fuses out of the fuse box that are not used for the starting circuit. This will keep you from burning up any of the 6 volt accessories. I would then bolt in a 12 volt battery and see if this starts your truck.
Brian Moore 1949 3100 5 window Deluxe "Today is better than yesterday, but not as good as tomorrow" | | |
