Joe,
Thanks for the info/tips. The primer is pretty soft stuff from what I have tried so far. I could see what you meant by the water not beading up any more. The guide coat is a black spotty spray as you mentioned over the entire truck.
Once I finish with the 400gr do I need to go over the truck with anything finer than 400 prior to painting or is that fine enough? Thanks again.
Steve
55 1st Series 3/4 ton
