| | | Forums66 Topics128,057 Posts1,055,812 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | Daves46pu, This topic was described in a recent post. Most likely you had a vacuum leak on the side of the insulator that did not have a gasket, usually the bottom of the insulator. A gasket on both sides of the insulator would most likely eliminate a vacuum leak. Also, the gasket between the insulator and the carburetor should have little "cut-outs" that must be aligned with a hole in the base of the carburetor. | | |
