The rule of thumb with epoxy is you can cover it with just about anything. You should check your tech sheet to rule out anything specific otherwise do what you need to do.
Good luck
36 Chevy 1.5 ton - rusting away 52 Chevy 3100 - in progress 72 Chevy K20 - DD
