| | | Forums66 Topics128,264 Posts1,058,352 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2004 Posts: 29,944 Kettle Custodian (pot stirrer) | | Kettle Custodian (pot stirrer) Joined: Feb 2004 Posts: 29,944 | What voltage? Are you running a generator or an alternator? The starter doesn't care what polarity it gets but a DC generator needs to be re-polarized to negative ground. it will probably be necessary to obtain a negative ground voltage regulator, since there are some internal wiring differences. The simplest approach will be to retrofit to a negative ground alternator if possible.
Does the truck have a series-parallel switch for starting on 24 volts? If so, that switch will probably have to be replaced with one for negative ground polarity. Jerry
