I am pulling apart my torque tube rearend looking for the bearing missing the pieces I found in the bottom of the housing.
I am now to the Drive pinion/pinion shaft assembly. Is pulling the assembly as easy as removing the front pinion bearing retaining screw? Or do I need to remove the torque tube from the housing?
I think it is the rear pinion bearing which is the problem.
Thanks, John
