| | | Forums66 Topics128,012 Posts1,055,318 Members48,419 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: May 2005 Posts: 8,878 . | | . Joined: May 2005 Posts: 8,878 | I've used brass plates and printed circuit etching methods to do similar projects. https://lh4.googleusercontent.com/-...9MHqyo/s1280/2012-12-25_13-38-12_809.jpghttps://lh3.googleusercontent.com/-...FbT0Os/s1280/2012-11-16_17-06-00_817.jpgIn this case you mask everything you want to be high, likely the letters and pattern and a border. Then everything else is etched away several thousandths of an inch. You can then either polish the high spots and leave the background as is or paint the whole thing and ever so gently sand the paint off the high spots. I have an aluminum Roadranger shift tag that is of a very nice style but not quite correct for my model transmission. I will eventually make the necessary changes and make a new one on a brass sheet. Grigg | | |
