I recently bought a '34 1.5ton with a '52 216 motor. The original wiring harness has been removed, and I believe the generator and starter are off of the same '52. I want to order a new original style harness (that has the voltage cut out on the generator). My question is can I instal a
voltage cut out on the generator that is currently on the truck? Or do the Voltage cut outs only work with specific generators?
