| | | Forums66 Topics128,021 Posts1,055,354 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Jun 2009 Posts: 1,596 'Bolter | | 'Bolter Joined: Jun 2009 Posts: 1,596 | You can have LED's in the same circuit as regular bulbs, yes. You may or may not need an LED flasher if you have regular bulbs in the same circuit. Try it first with your regular flasher, and if it doesn't work then you can get the LED flasher. It's just trial and error as it depends on your specific wiring and bulbs.
My '62 Bel Air has LED taillights but incandescent front lights, and the regular flasher works great.
My '46 has LED front and rear and needs the LED flashers for both signals and 4-ways. | | |
