7 members (Donf, Gdads51, 55shaker, TUTS 59, Forty9, Donsz, Gray_Ghost),
126
1
robot. | | Key: Admin,
Mod | | | Forums66 Topics128,056 Posts1,055,799 Members48,426 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | yes, I decided against going roller because they weren't a close enough match, but those bearings are what folks report being supplied by the vintage vendors for the swap, and after much research, including via the main major bearing specialty place here I've not found anything closer .... also I've never had any problems with the balls on many different trucks so don't see the usefulness, although it's commonly said it's best to do if going to disc brakes
Bill | | |
