| | | Forums66 Topics128,020 Posts1,055,345 Members48,420 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Oct 2013 Posts: 219 Shop Shark | | Shop Shark Joined: Oct 2013 Posts: 219 | Hello All,
Has anyone adapted hazard lights to their original wiring in a task force truck? My goal is to keep existing equipment and just add a switch. I'd rather not use a Yankee or Signal Stat setup if I can avoid it. I found a diagram that employs two relays and I would need to activate the turn signal then turn on the hazard switch. I only want to use one relay for double duty and use the hazard independent of the turn signal. I am a novice when it comes to electrical so figuring out this one is past my level of understanding. Has anyone done this or have any insight?
Thanks in advance | | |
