Here is something similar but is a bit bigger. I'm looking to do something like this for my '40. I have to do something before I drive it again because I welded up the fuel opening in the cab! I'll use a filler from a Lil Red Express that is exposed on the outside and enters through the panel below the bed. Not sure if the tank in this link will fit though. Haven't checked.
http://www.oldchevytrucks.com/cart/product.asp?prodid=MEG159&i=|gas tank||||
After looking at JC's description a bit closer, maybe it is the same tank as suburban/panel but includes all the mounting hardware.
Dennis
