9 members (Peggy M, dt235sd, 50Chevy3100, klhansen, Hush, Charles in CA, Nick in Manitou, 41 chev, 1 invisible),
344
Mod | | | Forums66 Topics128,270 Posts1,058,408 Members48,485 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Feb 2002 Posts: 12,029 Cruising in the Passing Lane | | Cruising in the Passing Lane Joined: Feb 2002 Posts: 12,029 | assuming the flasher pins are actually marked, orientation doesn't matter, the function will be the same - try checking the flasher pins with a meter, for continuity at rest and voltage in action, I believe L and P alternate hot when working, that is the pilot light actually blinks between the signaling light blink .... and don't depend on the colors for connections to the flasher, use the letter markings
Bill | | |
