right, good point about the truck being on tires and on the ground, might want to make sure it is level, are you going to lower it, I suppose if you are concerned about the weight issue,you will need to weigh it. never realized that weight played a factor but ... maybe 46 jimmy will chime in, he is good at this stuff, what ever he says you can take it to the bank... wait, back up the truck, put the body and stuff on and be good to go for the angle,
