| | | Forums66 Topics128,030 Posts1,055,424 Members48,422 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Apr 2004 Posts: 35 Junior Member | | Junior Member Joined: Apr 2004 Posts: 35 | "Lazarus" has a pretty good body with little rust. The only problem is with the front right fender. The back bottom of the fender is folded in pretty far and has a fold "crease" in it. I have tried almost everything I know to pull it back out, even tried using a "BIGGER HAMMER" with no luck. Is it necessary to heat up the metal to straighten this out? I am by no means a body man and if I can help it, don't want to take the fender off to work on it. Any suggestions? Thanks :rolleyes: | | |
