8 members (Steelonsteel, Gdads51, TUTS 59, Gray_Ghost, ESum, Ponchogl, bobwithm, Maybellene),
96
3
Mod | | | Forums66 Topics128,088 Posts1,056,125 Members48,435 | | Most Online14,466 Apr 26th, 2026 | | AD Chevy Trucks Over 6,000 pictures Brad Allen has an awesome collection of Chevrolet factory pictures that he has set up from film strips. Check them out!
on the Internet for over 30 years! and not clogged down with Ads! Again, thanks! | | | | Joined: Sep 2001 Posts: 29,269 Bubba - Curmudgeon | | Bubba - Curmudgeon Joined: Sep 2001 Posts: 29,269 | You are correct about poor valve-lash settings due to the indentations you describe (" . . number of the rockers have worn spots where they meet the valve ends - little round indentations. . . ). One old "solution" was to trim the feeler gauges so that they were small enough strips to fit in the indentations (ugh).
I have carefully ground/polished the rocker surface where they meet the valve stem.
Pre '68 Dave might have better advice.
