I just purchased a 1935 1/2 ton truck that has a hydraulic brake set up. I believe the brakes are from a 1936 (everything from the master cylinder to the
Brake/clutch pedals. Neither the clutch nor brakes have linkages. I need help understanding.the.linkage setup from the pedal to the clutch fork, and the brake linkage also.
